SeeLevel II Bluetooth integration for 709-BTP3 in Cerbo GX MK2
The SeeLevel 709-BT is a SeeLevel device which broadcasts tank information over bluetooth. This feature request is to integrate it into the Victron Cerbo GX MK2.
In my Airstream, there is no easy way to get a cable from the wall the Seelevel is in to the Cerbo. It would involve removing most of the kitchen.
Decoding the packets received on bluetooth looks like it is trivially easy [1].
Garnet 709BT BLE Technical Document
The Garnet 709BT hardware supports Bluetooth Low Energy (BLE), and is configured as a Broadcaster transmitting advertisement packets. It continuously cycles through its connected sensors sending out sensor data. No BLE connection is required to read the data, instead the smartphone application implements Receiver functionality to receive these packets.
When the application receives these packets it must decode the Manufacturer Specific Data to determine the Garnet Sensor Data. The first 2 bytes represent a company identifier code.
Company ID 305 Cypress Semiconductor
The following bytes represent the Garnet Sensor Data payload:
Byte 0, 1, 2 Coach ID Unique number - hardware assigned
Byte 3 Sensor Number 0-255
0 = Fresh
1 = Black
2 = Gray
3 = LPG
4 = LPG 2
5 = Galley
6 = Galley 2
7 = Temp
8 = Temp 2
9 = Temp 3
10 = Temp 4
11 = Chemical
12 = Chemical 2
13 = Battery x 10
Byte 4, 5, 6 Sensor Data ascii characters representing data value or sensor status
Byte 7, 8, 9 Sensor Volume
Byte 10, 11, 12 Sensor Total
Byte 13 Sensor Alarm
The link below [1] has code which can be used to read the signals, but the spec above makes it plain how to read them.
Please integrate this so I can display the tanks on my Cerbo GX without having to spend thousands and thousands of dollars trying to run a wire.
[1] [New Sensor]: SeeLevel 709-BT tank level sensor · Issue #1181 · custom-components/ble_monitor · GitHub
Any updates? The BLE version is cheaper than the hardwired one. Seals like a better option as well.
Plus 1, PLEASE!
I have a more permanent solution I’ve sent via PR to Victron linked in the ticket here: Add support for SeeLevel II Bluetooth integration for 709-BTP3 · Issue #1508 · victronenergy/venus · GitHub
However, when I couldn’t move forward on my own, I built a Python revision: GitHub - TechBlueprints/victron-seelevel-python: SeeLevel 709-BT Bluetooth to Victron Cerbo GX for monitoring RV tank levels, temperatures, and battery voltage which you can use now.
Being able to get my Seelevel tank sensors into my GX via their BT would be spectacular! I don’t have the RVC model. -Bill
I just received a notice from Victron that the new Cerbo Firmware supports Seelevel BT integration. Can’t wait to test that out. But I will wait a bit as we are on a 5 month trip right now and don’t want to take a chance with day old firmware.. -Bill
