Schaudt Elektroblock and Victron Orion 12/30
Good morning,
In my Possl camper with EBL 119 control unit and Schaudt Booster WA 121525 I replaced the AGM batteries by installing 2 lithium batteries of the same amperage (Ultimatron). I correctly set the control unit charger to GEL/lead and Lithium on the booster. After a few km the booster stopped working. Dead. I then purchased a Victron Orion 12/30 dc/dc which I installed in place of the Schaudt 121525.
The dc-dc does not work, it does not recharge the batteries, perhaps because the control unit configuration is not correct.
Do you know how to make the EBL 119 Elektroblock and the Victron Orion dc-dc work? thank you very much
this is the connection with the old Schaudt Booster. Now I put an Orion Victron 12-12/30
I have done a same rebuild with the EBL119. You have to disconnect the start battery from the EBL119. And only connect the start battery to the Orion. Also you have to remove the 20A fuse from the charger and use another extra charger for wall connection with lithium specifications. The internal charger of the EBL has no power enough for the lithium setup (not designed for this).
Hi Sander, I know this is an old thread but I am doing a conversion that’s similar and spotted your reply. I am removing a WA121545 and replacing it with a Victron Orion XS 12/12 50 and also have an EBL119. My question is: You mentioned removing the starter battery from the EBL at E20 3F, do I wire the output from the Victron to that port instead?
Hello
Yes the red wire from the battery has to enter into the Victron
In Victron website you can find a pdf: it’s explained well
F
Great thanks for taking the time to reply
Just realised I have already looked at the Victron pdf and it doesn’t answer my question. The WA121545 already has a wire from the starter battery so I can use that as the “in” to the Victron XS but the rear of the EBL119 has 3 ports, Earth, live out to the leisure battery and the other is connected to the WA121525, it is this wire I am interested in and do I wire that to the “Out” of the Victron?.
You have to disconnect the start battery from the EBL119. And only connect the start battery to the Orion. The only connection to the EBL is the brown and black connection directly from the Lithium (I have used a battery protect and a fuse for this connection).
Thankyou for the clarification, your picture confused me in that the output from the Orion appeared to go the the EBL and I thought that it meant that it went to the original starter battery position on the rear. So the output from the Orion just goes to the Lithium positive.
Hi can i ask a question regarding this please
The wiring between the 4 areas is
1 non isolated orion IN port to engine battery, (nothing into the GND or OUT ports, they remain empty?)
2 ebl 99 rear ports going left to right, nothing in the Rot port and with the Braun and Scwartz ports, (or minus and positive), cable black and red running to the lithium leisure battery.
Would this be correct, are there any other steps required and would you have a simple schematic i could follow please?
Kind Regards declan
Hi, I have the vehicle not with me for the moment, is it okay if I reply you later?
The orion is fully used, IN to the battery engine, GND to GND and de OUT to the Lithium.
Disable the charger of the EBL and/or Shaudt booster.
And only connected the black and the red to the lithium I think, but the latest I will confirm this later.
Kind regards,
Sander
Thank you for your reply, i appreciate any help you can give me
Kind Regards
Declan
Hi Martin attempting the same as you ,did you get this sorted? if so what was the procedure and instructions , tia Peter
Hi Declan
We are on the road right now, so you can ask any question you want.
The EBL is only connected with the household battery, for the lithium setup you have to disable everything that could charge the battery on the old way.
Kind regards
Sander
