SCC doesn't enter absorption, just keeps charging past 100%
New to Victron, and don’t understand why the 2 charge controllers are both still in bulk charge mode even after the battery has hit 100% SOC.
I have configured both charge controllers with the Smart Lithium pre-set, and only changed 1 value (float voltage to 13.6v as per the battery manufacturer manual at 12V 460Ah Heated & Bluetooth LiFePO4 Battery - Epoch Essentials)
Also, I confirmed in the mobile app for the battery (not Victron app) that the SOC was 100%.
Setup:
  • RV travel trailer, 12v
  • Epoch 460 LiFePO4 battery (12v)
  • 100/20 SCC for ground deploy solar
  • 100/30 SCC for roof solar
  • SmartShunt 300 with VE.Smart network to communicate voltage and current
  • Cerbox GX with DVCC disabled
  • Smartbattery Sense module
Why did the bulk charge mode stay in place right up to 100%? Am I overcharging the battery now? Why didn’t the SCCs disable charging?
Hi. The short answer here is that they remain in Bulk because they haven’t yet reached Absorb V.
Until they do there’s no danger of overcharging. And you have lots of V readings that match well to feel safe.
The battery is also still accepting current, so it’s not at 100% SOC anyway.
If this is a new installation, just let the chargers do their thing and charge it up fully to the target Absorb V. The SOC is a calculated figure (wherever it’s coming from), and it should then have a fully-charged base to work from (ie. a proper reset).
With a Cerbo in place, best not use the Smart Networking as well. That can cause weirdness sometimes, and not recommended by Victron.
A lot of new lithium batteries do not have an accurate SOC when supplied, they rely on getting fully charged the first time to synchronise the SOC to 100% with the point when the charger gets them full for the first time by going to float.
Thank you both for the great feedback. Much appreciated.
