I have a two-battery setup with a starter lead-acid battery and a LiFePO4 house battery. Both batteries are monitored via a BMV-712, each battery is charged from on-shore power via a Phoenix Smart Charger. The house battery is also charged via MPPTs from solar and the starter battery from the alternator when the engine is running. Moreover there is a Orion DC-DC from the starter to the house battery.
To allow coordinates charging between the different chargers for each battery I want to connect the chargers either via VE.Smart Networking or a Cerbo GX. (I am not sure what I am going to use. Probably I go for the more cost efficient solution with a VE.Smart Network).
My question is: Do I need to setup to different VE.Smart Networks (or two Cerb GX for that matter) to coordinately control two sets of chargers or can I use the same VE.Smart Network for everything?
The crucial point is that the Phoenix for the starter battery must be controlled via the BMV-712 connected to the starter battery and the Phoenix for the house battery plus the other chargers (MPPT, Orion) must be controlled via the BMV-712 connected to the house battery. Also only the chargers for the house battery must coordinate charging of the house battery among each other while the Phoenix for the starter battery is out-of-scope.
I am not sure if a single VE.Smart Network can do that. However, a single VE.Smart Network has the nice benefit that the user sees everything at once. Same for the GX: A single GX has the nice benefit that I see everything at once in a single dashboard, but I haven’t found any information whether a single GX can use two battery monitors where each controls a distinct sets of chargers.
Here is a summary of the setup in bullet points:
- Starter battery (lead-acid)
- 1st BMV-712
- Phoenix Smart Charger IP43 120-240V
- Alternator
- House battery (LiFePO4)
- 2nd BMV-712
- SmartSolar MPPT 75/15
- Orion-Tr Smart DC|DC 12V (from Starter to House)
