I have upgraded to a cerbo GX and transferred all sensors across. I have fitted a piezo resitive 50mbar tank sender to the diesel tank which works great. I then decided to install a Safiery Star tank senser to the water tank. I have xset it up with single green LED for small tank but the sensor shows 238cm and no matter what I do it will not clear and read correct value. The temperature and battery voltage appear correctly. I have followed everthing AI has thrown at me but it still reads 238cm . Any ideas would be appreciated. Getting support from Safiery is one of the worst tech support Companies I have ever dealt with so if you are thinking about buying one BEWARE the email they give for support comes back as Mail cdelivery system
Related topics
| Topic | Replies | Views | Activity | |
| Safiery Star Tank Sensor not working for diesel With Cerbo GX | 9 | 114 | April 15, 2026 | |
| Connecting Veratron Flex 52 nmea guages to 2 x Safiery sensors on Fuel and water tanks | 0 | 20 | July 22, 2026 | |
| Water and diesel tank sensors | 3 | 80 | June 10, 2026 | |
| Low reading for tank sensor on Cerbo GX | 4 | 252 | January 12, 2025 | |
| Safiery Star-tank sensor in Cerbo GX - custom shape not available | 13 | 917 | July 17, 2025 |
