This not so much of a question as something helpful for people going forward. I had a very unpleasant breakdown of my system the other day. I surmise it had a lot to do with the lack of space which I only found out when running an npm install command and it errored out with a lack of space.
If you run df -h in the shell then look for the space against /data
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/root 1201704 984680 140608 88% /
devtmpfs 465376 4 465372 0% /dev
tmpfs 515040 956 514084 0% /run
tmpfs 515040 516 514524 0% /var/volatile
/dev/mmcblk1p5 1134336 186856 871808 18% /data
/dev/mmcblk0p1 61341468 1231104 56964640 2% /run/media/mmcblk0p1
tmpfs 515040 956 514084 0% /service
Mine was 22M available before I took this capture. You might need to take action. I moved the node red folder onto my SD card. This might need relinking after each update which will need a script in rcS.local. I’ll test and update after the next update.
So I took the following steps.
Shutdown node-red from the cerbo remote.
cd /home/data
mkdir /media/mmcblk0p1/data
cp -a nodered/ /media/mmcblk0p1/data/
ls -al /media/mmcblk0p1/data/nodered/.node-red/ <--- Check its all there
rm -r /data/home/nodered
ln -s /media/mmcblk0p1/data/nodered nodered
restart node-red from cerbo remote.
This seems to be working fine.
