I’m having trouble with the pinouts and RpiGpioSetup. I want relay 1 to control the genstart. I assumed by default relay 1 was set to pin 2,4 or 12. With gen start voltage should be 0 and 3.0 when genstart is selected. 2 and 4 are 3 v and don’t change when gen start is selected and 12 is 0 v and also doesn’t change.
What are the relay pinouts. Do I need to set them from the command line? Thanks.
My apologies. Just after sending my request I found the pinout pdf. All good.
