I have Multiplus 24/3000/70-50 120V and a BMV-712 smart. I am attempting to auto start / stop a 6Kw Kubota Diesel generator.
The generator controller is working correctly. I can short / open the 2 wire start pins and the generator will start / stop. With VE configure, I selected “dedicated generator control” and sent the config. Under “Generator control,” if I invert the auxiliary relay, the generator starts. Using the Gui, I set up the Relay to use Gensat stop/start. I setup the generator under “Devices/Gensat” to start the gensat at 75% and stop at 90%. On the gui, when using “manual start/Stop” all appears to work, but the relay won’t activate, so the the generator doesn’t start. This is using a Raspberry PI V3, running the Venus OS V3.75.
I wired this up using the BMV-712 and it works, but failed to control it from the gui as well.
Any thoughts or suggestions?
Regards,
dmh
