Does anyone knows about a good resistive water level sensor compatible with Cerbo GX and good accuracy, meaning numerous and short steps of resistance ranges. I have a tank with a special shape to fit above the van wheel and the current sensor I used has only a few steps of resistance in its highest portion , where I would need more numerous and smaller steps between 2 resistance readings . I used an Osculati sensor of 60 cm but its resistance curve is not suitable for my tank. Thanks for your help
Related topics
| Topic | Replies | Views | Activity | |
| Easiest/cheapest option for single water tank sensor on Cerbo GX | 1 | 135 | 14 July 2025 | |
| Issue with resistance input range on Cerbo GX – sensor reads above 300 Ohm | 1 | 58 | 21 May 2025 | |
| Tank Probe CBE - SPE vs Cerbo | 1 | 148 | 19 June 2025 | |
| Victron Energy GX Tank 140 | 3 | 70 | 18 August 2025 | |
| Wired LPG level sensor | 0 | 38 | 15 November 2025 |
