Renogy Core Lithium 100Ah and MPPT 75|10 Settings
Hi all, I have a 100Ah Renogy Core battery on my solar setup.
Following a fairly deep discharge this December (the first one that ever happened) I did bring the battery home and slowly topped up back to 100% from the mains over a few days (1A Noco charger).
Reinstalling everything I was checking the MPPT setting for the battery. Attaching a screenshot.
Following what indicated on the manual regarding Absorption. Not sure where I got the 13.5v float voltage.
Battery should be fully charged at 13.6v.
I’m attaching a screenshot from the manual.
I’m confused by boost voltage.
Thanks in advance for any suggestions, pointers.
Your settings are OK, the 13.5V float is Victron default that holds the battery just below 100% full. I would not worry about boost, some chargers have a slightly higher voltage to boost charge. Victron chargers do not have boost function.
Thank you for the clarification!
