Question on Multiplus 2 operating
Everything was operating normally. I turned the multiplex off, unplugged from shore power, turned off batteries and installed fuses in distribution to get rid of red lights. When I turned on everything, it appears my multiplex is not recognizing shore power and only inverter is working. Video shows my display.
Yes I’m still learning how this is suppose to operate so again thanks to all replies.
Because they are programmable the first thing we need to know is how is it programmed?
My problem is no AC in 1 now.
There has to be a reset on the multiplus 24/3000/70 that I’m missing. I have confirmed 50 amp service going into it
We’d have more data in the detail view, showing voltage, frequency, amps…
For the record when I screw up I have no problem calling myself out as a dumb……
Took walls apart in storage bay just to check shore power splice to multiplus in electrical box only to find 1 leg pulled out of connector. Needless to say I’m up and running now.
Thanks again to all who tried to explain basic logic
Dave
