Quattro trips mains when set to on, no batteries connected and
Quattro 24/5000/120A 240Volt
On a ship, Batteries detached. need 240 power.
When set from off to on, Quattro light “battery low” for few seconds. Then some klikking and then mains are Tripping.
There is no load on the ship side of the Quattro.
Need some help
You can’t run the unit without batteries
It’s not possible to use the Quattro as a pass through in any form?
With the 240v power from a generator the Quattro is doing well. Also with no batteries connected.
It is unsupported because it will be damaging the device and shortening its life.
Those units have never supported use without a battery.
Fit a bypass switch rather.
The Quattro has a large bank of the capacitors on the DC input, when you try to run it on ac the ac tries to charge these capacitors with a huge inrush current many times higher than the unit is rated for.
Thanks for the info.
@nick Just a bypass switch just a connection between in and out? No other safety equipment?
Have a look in Section 6.6 of Victrons Wiring Unlimited. The bypass switch needs to be a dual changeover switch.
https://www.victronenergy.com/upload/documents/The_Wiring_Unlimited_book/43562-Wiring_Unlimited-pdf-en.pdf
Thank you for your help.
D.
