Quattro remote start/stop generator
Hi All, I have a Quattro 24/8000 and a generator. I believe the Quattro is setup with the generator assistant app to start/stop the generator. Is there a way to trigger it to start/stop remotely or via VRM?
Also, is it able to sense the generator no longer running if it’s manually stopped? To be able to re-trigger it to turn on? At the moment, if you manually stop it, it doesn’t re-trigger on another alarm.
I think that in addition to the Quattro. You can add a generator controller and monitor from remotestartgenerator.com. It would allow you to control the generator without having wifi as it works over cellular as well. I believe it would work in conjunction or as a stand alone system with the Quattro.
