Hello I have a Quattro 24/3000/120 installed on my boat. I have a 17 KW 240 volt generator. The Quattro is fed through a 240 volt to 120 volt Step Down Transformer to maintain load balancing on the generator. I have a Cerbo GX connected to the ve bus among other components. I am using the relay on the GX device for auto start functions of the generator. This is working very well however, when the generator shuts down the 240 volt equipment is not happy with the soft voltage drop and requires to be reset with a clean power cycle using the breaker. I want to install a 240 volt contactor on the 240 volt bus and wire it to the Quattro so it follows the internal transfer switch. Is there any programming functions available that allow me to set an auxiliary relay to follow the internal transfer switch for this application. Thank you
Related topics
| Topic | Replies | Views | Activity | |
| Quattro 120 Connect to 240 volt Shore Power - Simple Diagram | 13 | 404 | 5 May 2025 | |
| External contactor/ transfer switch for large quattro /generator system | 7 | 206 | 26 August 2025 | |
| Cerbo GX Generator start stop | 4 | 285 | 18 October 2024 | |
| Manually switching Quattro relays from VRM | 1 | 102 | 7 June 2025 | |
| Cerbo genset set up | 2 | 113 | 4 March 2025 |
