Super! Thanks for this - really appreciate it. Will give it a try now.
It is set to no grid code compliance with widest range of tolarance, it still stays after a while in AC disconnected state. This is a mountain cabin which requires almost a 4 hour round-trip so don’t have the luxury to test with breakers ![]()
Yes, here is the config file downloaded just now.
PCJ__c0619ab55099_inst_ttyS4_Interfaces_Mk2_Tunnel.rvms (9.1 KB)
Install VE Configurator. Part of VE Tools.
There isn’t any on generator. It was suggested in one troubleshooting guide to try disabling it hence the setting. Make no difference.
To be honest it still does the same behaviour on latest Inverter firmware update. Very unreliable how it connects AC inputs. You never know what to expect from it now.
Is the node-red flow I put together working?
Interesting thread, I think there is probably something Victron can do to improve this situation as well without requiring the work arounds. Even though they seem like the best solution available now.
I will pass it on internally.
Top job! Works well! Thanks a lot for it.
Hi Guy, perhaps you could have a read on my situation which is very similar actually. 1 Phase Parallel Quattro system frequently disconnecting from Grid & Geny running not detected - Q&A and troubleshooting - Victron Community
Hi @dansz , @owenb79, have been reading and learning a lot from you all here, I have a similar situation you might find intriguing, any expert advise would very helpful. System based in the UK: 1 Phase Parallel Quattro system frequently disconnecting from Grid & Geny running not detected - Q&A and troubleshooting - Victron Community
Meant to tag @nickdb in as well ![]()
