Quattro green light
New quattro about a month old. Shut off last night tried to turn it back on only green light inverter on is lit. Nothing else happens. Tried to disconnect the BMS cable and reconnect it get an alarm saying BMS lost connection clear alarm but still doesn’t go passed the green light inverter on.
Any ideas?
Have you looked at this?
Introducing The Victron Toolkit App - Victron Energy
Might give you some pointers…
also…
Check:
  1. You have battery voltage at the inverter terminals?
  2. Have you checked resistance across the fuse?
  3. Have you checked resistance between battery (-) to inverter (-) and battery (+) to inverter (-)?
  4. Is the AC output isolated, i.e., no chance of a short on the output?
  5. Is the AC input isolated, i.e., no chance of a short on the input?
  6. Is everything unplugged from the VE.Bus ports?
So got it working but I just noticed that it only inverts on shore power. If connected straight to 12v it doesn’t invert to 230v.
Batteries are at 13.12
Found this on the old community, not sure if it will help?
Quattro no DC power out - VictronEnergy
and
https://communityarchive.victronenergy.com/questions/234966/quattro-not-inverting-line-2.html
