Quattro Auto Transfer Slow
With the Quattro connected to Shore power, then starting the Generator, how long should it take for the Quattro to auto switch over the Generator? In some cases, this takes 10-20 minutes. Is that considered normal or acceptable? The Generator is connected to AC Input 1 at the Quattro. Are there settings in the set-up configuration that impact this?
It is usually within the first 2 minutes at least an attempt should be made.
Virtual switch or conditional AC connect -is that active?
Otherwise the grid tab settings would have alot to do with it.
See generator FAQ
