That’s a classic argument, and on paper, the redundancy of a multi-pack setup like 3x US5000 sounds great: if one pack fails, you still have 66% capacity.
However, in real-world DIY installations, physical and electrical reality often tells a different story.
1. The “Single Point of Failure” paradox
By splitting your storage into 3 separate packs, you aren’t just adding redundancy; you are multiplying your failure points by 3. You now have 3 internal BMS boards, 3 sets of internal fuses, 3 times the internal MOSFETs, and 3 times the physical connections.
2. The communication daisy-chain vulnerability
In a multi-pack Pylontech setup, the batteries communicate in a Master/Slave cascade. If a single cheap RJ45 link cable oxidizes, wiggles loose, or gets interference, the Master BMS loses track of the stack. When that happens, the system doesn’t run at “66%”—the whole battery bank safety-trips, and the Cerbo GX shuts down DC power. Your redundancy is killed by a simple comms link.
3. Balancing and maintenance nightmares over time
If one US5000 actually fails after 3 or 4 years and you send it back for warranty, running the remaining two is fine. But when the replacement/repaired pack comes back, you will be mixing a brand-new pack with two aged packs (different internal resistance, different SOH). Re-balancing that bank so they charge and discharge evenly without one pack tripping on overvoltage/undervoltage is a massive headache.
4. Cable clutter, connection points, and resistance
To run a 3x US5000 setup safely and avoid overloading the proprietary Amphenol connectors on the first unit (which are thermally limited), you cannot simply daisy-chain them in a single row. You are forced to split the stack into multiple cable runs going to a common busbar (like a Victron Lynx).
This means managing multiple sets of heavy-gauge DC cables of identical lengths to ensure equal resistance, doubling the number of connection points, and multiplying the risks of a poorly crimped lug or a slightly loose connector that would unbalance the whole bank.
5. Simplicity vs. Redundancy
For a stationary home system, which strategy actually brings more real-world reliability?
- Is it better to choose simplicity with a single, robust 16S monoblock (like the Pytes V16) to eliminate 90% of the wiring, balancing, and communication failure points from day one?
- Or is the theoretical redundancy of a multi-pack system (like 3x US5000) worth the added complexity and the manual troubleshooting required when a failure actually occurs?
I’d be curious to hear your thoughts and real-world experiences on this balance between simplicity and modularity!
