AIC Ratings for LiFePO4 - Class T - MRBF
I’m trying to get some information surrounding AIC (Ampere Interruption Rating) ratings and appropriate fuse types for LiFePO4 installations.
I’m still working this all out so please let me know what I’ve gotten wrong.
It seems like the extremely low internal resistance of lithium batteries allows them to drop huge amounts of current very quickly when something goes wrong. This necessitates the use of fuses with much higher AIC ratings.
I have a couple of installations that are fused with MRBF fuses (One is 12VDC @ 2.5KWH) and the other 48VDC @ 10KWH) so I’ve been trying to work out whether they are adequately protected or need to be fixed.
There doesn’t seem to be a huge amount of information around and it would seem like lithium batteries are relatively new so information, guides and hardware hasn’t kept up. It was only this year that Victron started offering anything other than MEGA fuse holders for batteries.
Anyway, hope I can find some guidance. Cheers.
Why do make a distinction between ‘battery fuses’ and ‘device fuses’ What are their different roles?
Battery fuses
a) Doesn’t fail in such a way as to continue conducting electricity.
b) Protects the battery from over-discharge
c) Protects everything upstream from catastrophic battery failure
Device fuses
a) Protects wires and devices from over current conditions.
Class T – Most often used as battery fuses
MRBF – Used as both battery and device fuses
MEGA – Should never be used as a battery fuse. Great as device fuses.
  1. What types of failure modes are we trying to mitigate, how likely are they to happen and how catastrophic can they be?
Battery fuses:
Catastrophic battery failure (What does this look like)
Battery over-discharge conditions (Which the BMS shouldn’t allow in the first place)
Wire protection
Device fuses:
Shorts
Devices drawing too much current
Wire protection
As far as I know, AIC ratings are affected by:
I’m not sure of the correct cell/battery/pack terminology here
a) Internal resistance of the battery
b) Resistance of the upstream wire
c) Voltage of the battery
d) Capacity of the battery?
What other systems could be in place as secondary protective measures?
  1. The BMS itself should have over-current protection – How is this normally implemented and how can it fail? Do more expensive batteries often have more/better protection?
I’ve seen recommended AIC values of: 10,000A – 20,000A short circuit current thrown around for LiFePO4’s
Would MRBF fuses ever be appropriate for use with LiFePO4 batteries? Even at 12VDC or are Class T fuses the only reasonable option?
It would seem that 12VDC setups are PROBABLY OK with MRBF fuses but anything higher voltage (e.g: 24VDC, 48VDC) will absolutely need class T fuses.
Any other advice while we’re here?
  1. Remember to pre-charge the inverter capacitors with a resistor or the capacitor inrush current might pop fuses and cause damaging arcs.
  2. Be careful hanging fuses off battery posts. Try to reduce the physical stress on it.
  3. The closer the fuse is to the battery, the better.
  4. Impedance/length match battery cables so they don’t go out of balance.
Thanks
Correct
I can tell you what we say on diysolarforum, but it just consensus opinion.
There is very little manufacturer guidance out there, and lots of incomplete information.
I am only addressing 48V nominal battery systems in these comments.
12 and 24V require significantly less protection because arcing is so much harder.
(a) is DC arcing, which is super dangerous and will eventually burn down something
(b) fuses only protect is the max discharge rate being exceeded, normal discharge rates will result in a flat battery eventually
(c) catastrophic or doomsday scenario protection are for if everything else fails
Other options for Class T are NH00 (UK, Europe, AUS) and EF3.
Anything with an interrupt rating above 10 kA, preferably 20 kA rated at least at 60V.
I’ve seen some new automotive fuses rated 20 kA at 125 VDC.
Now that is protection.
Catastrophic battery failure can occur when a cell develops a bad short internally.
In this case, depending on the topology of the battery system, an array of fuses or
circuit breakers can help mitigate having every battery dumping all of its energy into the shorted cell. DIY batteries have burned down people’s houses because of this.
Or when a dead short occurs on the output wiring, or when an inverter dead shorts, etc.
You cannot rely on a BMS to protect you. If it has a contactor, it can get welded shut.
If it has MOSFETs, they typically fail in a dead short. Some rack mount batteries have
an inexpensive DC breaker. The reliability of those are questionable at best.
(a) and (d) go hand in hand, because as you parallel more batteries together the effective internal resistance goes down (e.g. 3 batteries in parallel will have 1/3 the resistance).
(c) matters for 48V and above, and you will notice that some fuses have really high interrupt ratings at 12V, but only 2 kA at 48V.
Covered above (contactors, MOSFETs, circuit breakers).
There is likely a weak correlation of price with quality.
The best thing to do is to look for torture test videos on YouTube for the battery in question.
I shoot for 20 kA. I don’t have time to entertain a doomsday scenario more than once.
Class T is overkill at 12V, MRBFs are great for 12V and 24V systems (IMO).
Put your Class T fuses in a proper fuse holder, which may cost more than fuse.
When it goes, you want mechanical strength and containment.
The biggest issue with lithiums being able to let out huge amps in short periods is actually arc faults, so you need a fuse that can both break the path and quench the arc.
Batteries have a high KA rating. Most breakers and fusing you see have a ka rating.
So you choice really depends on if that has the potential to happen.
@ricardocello
@lxonline
Thank you for the input. I guess I’ll rip out the MRBF’s on my 48V Pylontech setup and get some class T’s in there. Is there just the one form factor for class T’s? You mentioned NH00 and EF3, what are these distinctions?
What’s the best way to attach an M8 Lynx distributor to an M10 Class T power-in?
It’s pretty frustrating to have two different incompatible lines of Lynx products. Are there any plans to release an M8 Class T power-in?
Thanks
Class T sizes are not typically standardized, unfortunately.
Pick a vendor (e.g. Littelfuse JLLN or bussmann/eaton JJN), a fuse rating in Amps, and find a matching fuse holder. The size gets bigger over 200A.
Sometimes fuse/holder are sold as a set.
There are off-brands on Amazon, I have no opinion on those. BlueSea uses the main brands.
https://www.eaton.com/content/dam/eaton/products/electrical-circuit-protection/fuses/bussmann-series-branch-circuit-fuses/class-t/bus-ele-ds-1025-jjn.pdf
https://www.littelfuse.com/assetdocs/jlln-datasheet?assetguid=2925cc6d-2278-44e0-8fdd-106f087f707e
NH00 and EF3 are different classes of fuses with similar high DC interrupt capability.
Not Class T, but just as good, easier to find in non-US markets and cheaper.
I don’t keep up with the Lynx developments, so perhaps someone else can help.
Hello @confusion , interesting question and thoughts in your post. Why should a MEGA fuse never be used as a battery fuse in your opinion?
Because they have much lower AIC ratings than what a lithium battery can dump out
Thank you. I don’t think I have taken that sufficiently into account when I designed and built my own system. Focused too much on the Amps of the fuse in my Lynx DC-in. But not on the LiFePo high current in case of a short and potential arcs melting down my fuse and busbar.
I will change that part of my system (2xUS5000) now and see two ways to do it within the Victron product range:
  1. Replace the MegaFuse in my current Lynx-in with a EF3 Fuse (50kA@200Vdc)
  2. Add a Victron Lynx Class-T Power In with a T-Class Fuse
Any opinions which way to go? Is a EF3 replacement in my existing distributor sufficient or should I upgrade the DC-bar with an additional Class-T Power In?
Couldn’t comment on the EF3 (Is it even a form factor that would fit the Lynx Power In?)
Yeah I think the general consensus is if it’s 12V you’re probably alright with MRBF’s but if it’s 48v you really need a class T. It’s a real pain, it’s not something anybody mentions either. I think the Victron Class T Power In came out in very late 2024.
I’m in the same boat. I have a PylonTech setup and I built it with MRBF’s and am now only realising that it should really have Class T’s in it.
But yeah, MEGAS are only really good for distribution to other devices e.g: Inverter, DC loads etc. as they can’t handle a LiFePO4 sh!tt!ng the bed.
I think MEGAS were fine for battery fusing when everyone was using lead acid as they have a much higher internal resistance. Maybe a lot a of guides and manuals haven’t been updated for use with LiFePo4’s hence they lack of knowledge/awareness of AIC ratings on fuses.
Happy trails
I decided now to add a Lynx Class-T to my system to connect my two US5000, each separate with separate Class-T fuse to the two ports of the unit. My Victron dealer is HusaTech in DE. Seems like the unit is not (yet) available at the moment. Will deliver feedback when I get one for installation.
Careful, I think the Class-T Power In only comes in M10, Some lynx distributors and power ins come in M8.
Yes, I was thinking about compatibility as well. At the moment, I see it this way:
  • From a current/load perspective, the M8 version is more than sufficient for my system. Current Power-In/Distributors are M8 versions.
  • Looking into the Victron datasheet dimensions and drawings, the units should be mechanical compatibel.
  • I hope, the M10 Lynx In Class-T can connect to my existing M8 Lynx units using M8 bolts and nuts with respective washers.
  • Worst case, I would need to replace the existing M8 units with M10 ones.
Let’s see how the reality looks like when I get the device :slightly_smiling_face:
Let me know how you go, I’m about to do the same thing.
@confusion , sure. Will provide an update here as soon as I get the unit and the fuses.
The BlueSea Class-T fuses arrived meanwhile. The Lynx Class-T module is set to delayed by the distributor and is now planned for mid of February to get shipped. I will let you know, whether and how it can get connected to existing M8 Lynx units.
Find two picture attached:
Very interesting. So is it the exact same form factor as MEGA?
I don’t know enough about fuses to say whether or not they would be appropriate for use with a 48v LiFePO4 system, I could ask over on diysolarforum.
I notice they start at 150A which sucks because most of the time I’d be wanting 100-125A right?
Super keen to see how you get on with the M8-M10 situation, much appreciated you keeping me in the loop.
Victron Mega fuse
Adler EF3
I never installed it in my Lynx, but 50,8 mm Mega Fuse spacing is within the range of the EF3 dimensions. Headspace should be sufficient inside the Lynx. M8 fits as well.
I just think, Victron had a reason why they developed a separate Class-T Lynx-In, so I just decided to skip that experiment and to go for the Class-T instead of an AF3 in my Distributor.
EF3 iin Lynx:
There is regular misinformation on this. If you calculate your Battery Resistance (manufacturer) you’ll find most cells cannot exceed interrupt rating of a Mega fuse.
Only if you Parallel several strings will you NEED Class T interrupt levels.
Check your mfr specs, and apply ohms law. You’ll see the max current, and that’s excluding all wiring, junctions, busbars etc, all of which will reduce that mac interrupt further.
People make Li out to be scarier than it need be. Ohm’s law isn’t new.
A Mega per string and a Class T for the group if paralleled might be worth doing.
Note - 100KWhr - thats multiple parallel strings. Most LFP cells in a single string cannot exceed a MEGA AIC. Check the mfr internal resistance and ohms law. Cells arent magic.
You dont need to do that. Pylontech knows what they are doing.
Single string is within the spec.
Parallel strings need more.
