Power measurement to Cerbo GX
I’m looking for an energy meter which I can connect to Cerbo GX, it’s for my RV. It must manage 230V and 16A. The problem is that I don’t know which cable is L and which is N on the incoming cable. Most outlets are a CE connector and L “should” should be on the correct pin, but who knows, it might be switched. And then there are schuko plugs. All devices I found need to be connected to L and N specifically.
Anyone manage to measure 230V16A on a 12V device and connected to CerboGX?
Anyone who knows a device which doesn’t need L and N on specific input feed and connects to CerboGX?
Cheers
