Phoenix Smart IP43 Charger Error 18 - @Victron, please help. The dealer does not know what to do
Thanks for the update.
What are you doing to mitigate the error? Reducing the AC or DC maximum amounts? One or both?
I generally avoid having the IP43 turned on in the first 45 minutes of the morning when I am using the inverters to produce AC for the various AC devices in the galley. i.e. coffee maker + hot water heater + microwave + toaster, etc. The IP 43 is already putting out 25 amps at 26vdc and is not able to understand that it should not try to deliver more than 25 amps when the inverters start drawing 50-75 amps from the batteries.
