Hi, I have a yacht with two engines each with 100 Amp generator can I parallel two buck boost 100 amp DC-DC converters, it is a 24 volt system. I will like to have 2*50 Amp charging current to my main battery. Is there any special set up of the two buck boost converter ?
In the tsconfig program there are mentioned a master/slave option can that be used.
Thank in advance
