hi everyone,
I have a problem for which I cannot find a solution.
I have a Multiplus II which, as is known, has 1 AC input, now I also have a new Panda Ficher 5000I Neo PMS, via a transfer switch I determine whether the power of the boat comes from the shore power or from the generator, that all works fine.
However, despite all information, the Ekrano (more like the Venus OS) continues to insist that the “current” comes from the shore.
That’s remarkable! Yes, the Multiplus II only has 1 AC input, not a second one like a Quatro, but that is not necessary, there is no other option than that the Multiplus either receives power from the shore or from the generator and how do you see that because the Panda Fischer offers the data.
The multiplus does not need to see where the current comes from.
Even with a separate Energy meter ET112 with the role “generator” Venus OS continues to say ; The generator is running and supplies power, but there is also power from shore! That also make a big mess in calculating the power consumed , but oke …………
Which is not possible at all. In my opinion that is really a big mistake, or I am really overlooking something, but so far it seems that way.
What is another strange thing is that I now have 2 generator pages, 1 Panda Fischer and another standard in the system, see the photo, when the Panda Fischer is running, the VRM page says “Stopped”, which is correct until I click on the standard screen, for example. start it manually and it will take it with it.
So it does not seem to be fully integrated.
That is quite remarkable considering that Victron and Panda Fischer work closely together.
So unfortunately I don’t see how I can make the routing in software so that it should work as it should.
So it is software nothing else, you really don’t need a physical second AC input because otherwise the software will no longer understand it.
In fact, if there is software, there is often no physical need anymore, which is why we now all call via VOIP and with the company number while we are sitting on the beach, in the past you really had to connect the cable of your company telephone device with a cable extension, to indicate that software changes things that previously could only be done physically and nothing more than that.
How the mulitiplus II is powered is not at all interesting, it is offered something and the software attaches a label based on data. it shouldn’t be more than that in my opinion.
But who knows, can of course say so!! ![]()
