In data sheet Output voltage: 277 VAC ± 2 %
However, the input voltage is 230-290 VAC.
So, I want to know Output voltage range that can be set in VE Configuration.
When you start VE - configue, and connect to the device, a dialogue box appears when you click on e.g. the ac output voltage. This tells you the limits that you can set the voltage between, as well as entering the desired voltage.
I found information of output voltage in datasheet
