Orion XS V1.15 Change log
Thanks for the feedback, I will forward it to the developers.
What are the implications of running two xs in parallel ?
I have found you can enable both together for twice the charge, if you enable only one the second one will start up as a charger and create a loop unless you disable it
You will find it has greyed out again as either the lock out or Engine detection is no longer active, crank battery voltage has risen
I thought as much, I’m writing a node red flow to enable one and disable the other, just waiting for the ability to enable reverse charge by code.
Matthias, if you have a direct line of communication with the developers can you raise the observation I found regarding the internal temperature change I found with firmware v1.15? I tried reporting it via TestFlight but it just bounced back.
