Orion XS dvcc glitch overcharging
I’m using an Orion XS is a non standard setup. I have an off grid system and using the Orion XS for charging batteries from my solar battery. It’s connected to cerbo along with all my other victron equipment. I’m having the issue of over charging when dvcc is enabled it goes 2v over set charging voltage. Is there any way around this and still be able to view and control via vrm?
As you wrote you don’t have a standard setup.
With the current software it is only designed to charge the main battery from another battery/alternator.
But with the next Venus OS other setups will be possible.
It’s currently in beta testing.
Thank you, will check it out.
Guess this is where the 1400 and bi directional charging would be best.
