Orion XS Bluetooth issues
I’ve got a head scratcher that I’m hoping you can help me with.
The Orion XS-50 in this installation is no longer showing up in VictronConnect and is not charging the house batteries. Seems like a Bluetooth issue but I can’t fix it despite following the troubleshooting guides. There’s also a weird buggy thing happening in the app where it keeps saying it lacks local network permissions even though I have given it permission. Maybe this is related? I tried downloading the app on a separate IPhone and the same permissions issue is happening there.
I’ve checked voltage and continuity at every point in the circuit and everything seems to be working. The blue Bulk indicator light is glowing on the unit. There is even voltage flowing from the output of the Orion to the Lynx distributor. No fuses are blown and there are no signs of damage to any wiring in any way. The unit was previously charging properly and stopped working randomly.
I swapped a VE Direct cable from the MPPT over to the Orion just to see if it shows up on the GX Touch Screen and it does. It seems like the input and output voltages are off when I open up the settings page on the touch screen, but I am unable to make any changes to it.
Wondering if I have a defective unit or if we made some mistake in the installation or setup of this unit. Hoping you can provide some guidance so we can hopefully sort this out quickly!
