Hello All!
I Hope you can help me find a solution for the following problem
Optimising EV charging from PV surplus in zero-feed-in ESS setup
System :
5 kWp PV array (SSW orientation, 45° tilt)
Victron:
MultiPlus II 5 kVA
MPPT 250/100
Cerbo GX
ET340
Lynx Distributor
3× Pylontech US5000
Goal :
Optimise EV charging using excess solar production .
We work from home and our VW e-Up! is usually parked outside during daytime, so charging directly from solar makes perfect sens e.
At the moment we charge using the standard portable charger at around 8 A (~1800 W). Charging is scheduled during off-peak hours (22:00–06:00) and limited to 80% S OC.
With 5 kWp of PV, we expect significant surplus production during summer once the batteries are fully char ged.
Because exporting power to the grid in France is administratively complicated, most systems here are configured for zero fee d-in.
The pr oblem:
An EV charger typically only starts charg ing at:
8 A with a basic charger;
around 6 A (~1300 W) with a smart charger.
However, with zero feed-in enabled, the MPPT output continuously adjusts to match actual co nsumption.
As a result, the system never creates a visible surplus of 1300 W, so the charger ne ver starts.
It becomes a chicken-and- egg problem:
no charging load → no extra P V production;
no surplus → no c harging start.
Possible solutions
- Control charging within Victron ESS
I understand there may be a way to manage this directly inside the Victron ecosystem, possibly using some sort of periodic charging test or dynamic control logic.
I would appreciate explanations from users already doing th is successfully.
- Allow limited grid export
Probably the cleanest te chnical solution:
allow ~1000–1300 W export;
start charging once export thr eshold is reached.
Unfortunately this creates contractual and regulatory compl ications in France.
- Create a t emporary “dump load”
a. Thermal dump load
Examples:
boiler
electric heater
resistive load
But in summer, when PV surplus is highest, additional heating is usually unnecessary.
b. Small inverter heat pump
For example:
a reversible pool heat pump connected to the 800 L floor-heating buffer tank;
creating “cold storage” during surplus production.
Interesting idea, bu t with practical challenges:
condensation
insulation
noise
plumbing complexity
limited seasonal usefulness
Question
How are others solving EV charging in a Victron ESS sys tem with strict zero feed-in?
Particularly interested in:
Victron EVCS experiences;
ESS configuration tips;
elegant charging strategies;
real-world examples.
