VRM > Settings > Location
The map is not wisible, but it looks like a link. Eve when i tryied download a map as a picture, it was just black. What is wrong?
If you’re using a web browser on pc or mac make sure that you’re allowing the browser to get you’re location.
I finally used different web browser and it worked. I set the position. I don´t need to use the map all the time, only wanted to set position to get forecast. So I´m OK wit this and now I´m using the original browser with not allowed position.
I am sure I´m not allowing. But I don´t want VRM to show my current possition. I only want to display a map and set the possition by hand. It might be caused by some ad block also. Anyway, this troubel is already solved for me.
Did the same, looks ok now
