c0619ab212b3_inst_ttyS4_Interfaces_Mk2_Tunnel.rvms (3 Bytes)
I am in the USA and have a dual split phase MultiPlus 3000 setup in my RV, which I live in full time. The last time I had it on the grid I was trying to configure the ‘dedicated ignore AC input’ and the ‘limit internal charger to prioritize other energy sources’.
Neither one seemed to work to my liking, so I thought I took it back to the basic config. Now I am back on 110v shore power the inverter group is not pulling in any power from the shore power. I am pulling everything from the battery.
I wonder if there is some configuration in the VE Configure 3 that enables the inverter on the L1 to charge when it is on 110v got unset or something when I was making changes.
Attached is my current configuration, can someone have a look and see if I have something set wrong?
