Thank you for your replies. I seem to have things more under control now. I think what was throwing me was that there seems to be an initial fallback to a default value somewhere.
But the following flow is basically what I’m looking for. I can tweak from here. Hope it helps someone else get started in the future.
"id": "e44b97ccfb3d7e87",
"type": "tab",
"label": "Octopus Power Down",
"disabled": false,
"info": "",
"env": []
"id": "a09882bdbe92de34",
"type": "change",
"z": "e44b97ccfb3d7e87",
"name": "Set Payload to -90W",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "-100",
"tot": "num"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 820,
"y": 140,
"wires": [
"4147210ea3bdb0dc"
"id": "66f71c613acc0964",
"type": "switch",
"name": "Diff depend on hour",
"property": "hour",
"propertyType": "msg",
"rules": [
"t": "btwn",
"v": "0",
"vt": "num",
"v2": "11",
"v2t": "num"
"t": "btwn",
"v": "11",
"vt": "num",
"v2": "12",
"v2t": "num"
"t": "btwn",
"v": "18",
"vt": "num",
"v2": "19",
"v2t": "num"
"t": "gte",
"v": "19",
"vt": "str"
"checkall": "true",
"repair": false,
"outputs": 4,
"x": 550,
"y": 200,
"wires": [
"a09882bdbe92de34"
"a536d6ac286b1db0"
"41b18b98157aad75"
"57a02921b771b0ba"
"id": "c6b9af939a101631",
"type": "moment",
"name": "Identify current hour",
"topic": "",
"input": "payload",
"inputType": "msg",
"inTz": "ETC/UTC",
"adjAmount": "1",
"adjType": "hours",
"adjDir": "add",
"format": "HH",
"locale": "London",
"output": "hour",
"outputType": "msg",
"outTz": "ETC/UTC",
"x": 320,
"y": 200,
"wires": [
"66f71c613acc0964"
"id": "7d508202fa488698",
"type": "inject",
"name": "",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "10",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "",
"payloadType": "date",
"x": 130,
"y": 200,
"wires": [
"c6b9af939a101631"
"id": "78ac1dee942a3c49",
"type": "comment",
"name": "For BST set offset to +1 hour",
"info": "",
"x": 320,
"y": 160,
"wires": []
"id": "4147210ea3bdb0dc",
"type": "victron-output-ess",
"service": "com.victronenergy.settings",
"path": "/Settings/CGwacs/AcPowerSetPoint",
"serviceObj": {
"name": "Venus settings",
"communityTag": "ess"
"pathObj": {
"type": "integer",
"name": "Grid set-point (W)",
"mode": "both"
"initial": 90,
"name": "",
"onlyChanges": false,
"roundValues": "no",
"outputs": 0,
"x": 1100,
"y": 140,
"wires": []
"id": "41b18b98157aad75",
"type": "change",
"name": "Set Payload to -1200W",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "-1200",
"tot": "num"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 830,
"y": 260,
"wires": [
"41cd2d97a02d1684"
"id": "57a02921b771b0ba",
"type": "change",
"name": "Set Payload to -100W",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "-110",
"tot": "num"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 820,
"y": 320,
"wires": [
"1e6327b4a97148b1"
"id": "1e6327b4a97148b1",
"serviceObj": {
"pathObj": {
"type": "integer",
"mode": "both"
"initial": 90,
"name": "",
"outputs": 0,
"x": 1100,
"y": 320,
"wires": []
"id": "41cd2d97a02d1684",
"serviceObj": {
"pathObj": {
"type": "integer",
"mode": "both"
"initial": 1200,
"name": "",
"outputs": 0,
"x": 1100,
"y": 260,
"wires": []
"id": "30bc8a3f4c3dcc99",
"serviceObj": {
"pathObj": {
"type": "integer",
"mode": "both"
"initial": -99,
"name": "",
"outputs": 0,
"x": 400,
"y": 360,
"wires": []
"id": "124ed347ec1e52db",
"serviceObj": {
"pathObj": {
"type": "integer",
"mode": "both"
"initial": 90,
"name": "",
"outputs": 0,
"x": 1100,
"y": 200,
"wires": []
"id": "a536d6ac286b1db0",
"type": "change",
"name": "Set Payload to -110W",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "-110",
"tot": "num"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 820,
"y": 200,
"wires": [
"124ed347ec1e52db"
"id": "441db679838c65e2",
"type": "global-config",
"env": [],
"modules": {
"node-red-contrib-moment": "5.0.0",
"@victronenergy/node-red-contrib-victron": "1.6.64"
