Works, only the color of the Victron nodes changed to gray.
And the colors are back to normal
I’ve seen those color changes a couple of times too, but this one is really hard to analyse. It isn’t consistently reproducible, which would really help. At the moment I am still unsure if the actual problem lies in the Victron node or in the underlying Node-Red version.
Almost all nodes in the victron node selection list colored gray.
But did see one or 2 blue ones (should have made a picture,…).
Do they all have the exact same color, if not it could be a missing color map (maybe 8 bit 16bit or 32bit depth color map)?
The orange was also gone.
Just reload the page, the colour will return.
Have grey icons quite often. Like Nick said, just refresh and all good. Think I noticed it first when moving to one of the earlier 3.70 beta’s. Not a real problem I guess.
Did you try reload the page.
The issue has been around a while in beta. It does not always happen but is always fixed by a page refresh.
Yes I did and colors are back, made the screenshot just for debugging.
Some victron nodes show correct and others gray.
All others (not Victron) are shown in the correct colors.
Can’t be color pallet, orange and blue is the same (in screenshot,R,G,B composition) if nodes are shown gray or shown normal.
Maybe this helps.
