Node Red ... Shelly Plus 1PM mit AddOn und Temperaturfühler schalten
Hallo, wer kann einem ANFÄNGER helfen….
Ich lese die Temperatur von meinem Temperaturfühler der an einem AddOn an dem Shelly Plus 1PM aus…. tc ist 50.8 Grad … Siehe Bild.
Ich möchte meinen Heizstab bei zB. größer50 Grad über einen shelly ausschalten
Und bei kleiner 40 Grad diesen wieder einschalten.
Wer kann mir da helfen ?
Grüße
Rolf
“id”: “47e0f52ffb50505a”,
“type”: “tab”,
“label”: “SOC&Heizstab”,
“disabled”: true,
“info”: “”,
“env”:
“id”: “cff94c69c7bac742”,
“type”: “debug”,
“z”: “47e0f52ffb50505a”,
“name”: “”,
“active”: true,
“tosidebar”: true,
“console”: false,
“tostatus”: false,
“complete”: “payload”,
“targetType”: “msg”,
“statusVal”: “”,
“statusType”: “auto”,
“x”: 1250,
“y”: 400,
“wires”:
“id”: “3d6b19b1c8d830eb”,
“type”: “function”,
“name”: “Heizstab on”,
“func”: “msg.payload = {\n method: "Switch.Set",\n parameters : {\n id : 0,\n on : true,\n }\n};\nreturn msg;”,
“outputs”: 1,
“noerr”: 0,
“initialize”: “”,
“finalize”: “”,
“libs”: ,
“x”: 830,
“y”: 380,
“wires”: [
“9b542dba0e875503”
“id”: “1a02fd82b833a65a”,
“type”: “function”,
“name”: “Heizstab off”,
“func”: “msg.payload = {\n method: "Switch.Set",\n parameters : {\n id : 0,\n on : false,\n }\n};\nreturn msg;”,
“outputs”: 1,
“noerr”: 0,
“initialize”: “”,
“finalize”: “”,
“libs”: ,
“x”: 830,
“y”: 420,
“wires”: [
“9b542dba0e875503”
“id”: “545e24f170f646c2”,
“type”: “inject”,
“name”: “Turn On”,
“props”: [
“p”: “payload”
“p”: “topic”,
“vt”: “str”
“repeat”: “”,
“crontab”: “”,
“once”: false,
“onceDelay”: 0.1,
“topic”: “”,
“payload”: “”,
“payloadType”: “date”,
“x”: 560,
“y”: 380,
“wires”: [
“3d6b19b1c8d830eb”
“id”: “aa1b3fb6c5e7dee1”,
“type”: “inject”,
“name”: “Turn Off”,
“props”: [
“p”: “payload”
“p”: “topic”,
“vt”: “str”
“repeat”: “”,
“crontab”: “”,
“once”: false,
“onceDelay”: 0.1,
“topic”: “”,
“payload”: “”,
“x”: 560,
“y”: 420,
“wires”: [
“1a02fd82b833a65a”
“id”: “6b0f15485bdbc33b”,
“type”: “inject”,
“name”: “Get Status”,
“props”: [
“p”: “payload”
“p”: “topic”,
“vt”: “str”
“repeat”: “”,
“crontab”: “”,
“once”: false,
“onceDelay”: 0.1,
“topic”: “”,
“payload”: “”,
“x”: 820,
“y”: 320,
“wires”: [
“9b542dba0e875503”
“id”: “6805ea47b25eec2d”,
“type”: “function”,
“name”: “0 toggle”,
“func”: “msg.payload = {\n method: "Switch.Toggle",\n parameters : {\n id : 0,\n }\n};\nreturn msg;\n”,
“outputs”: 1,
“noerr”: 0,
“initialize”: “”,
“finalize”: “”,
“libs”: ,
“x”: 820,
“y”: 460,
“wires”: [
“9b542dba0e875503”
“id”: “ba6cc705a48c3b5f”,
“type”: “inject”,
“name”: “Toggle”,
“props”: [
“p”: “payload”
“p”: “topic”,
“vt”: “str”
“repeat”: “”,
“crontab”: “”,
“once”: false,
“onceDelay”: 0.1,
“topic”: “”,
“payload”: “”,
“x”: 550,
“y”: 680,
“wires”: [
“6805ea47b25eec2d”
“id”: “9b542dba0e875503”,
“type”: “shelly-gen2”,
“hostname”: “192.168.178.57”,
“description”: “”,
“mode”: “polling”,
“server”: “04263f2d054cc2a1”,
“uploadretryinterval”: “5000”,
“pollinginterval”: 5000,
“pollstatus”: false,
“getstatusoncommand”: false,
“devicetype”: “Relay”,
“outputs”: 1,
“x”: 1040,
“y”: 400,
“wires”: [
“cff94c69c7bac742”
“id”: “a32dc79cbe0aa215”,
“type”: “victron-input-battery”,
“service”: “com.victronenergy.battery/512”,
“path”: “/Soc”,
“serviceObj”: {
“name”: “Pylontech US2000C”
“pathObj”: {
“path”: “/Soc”,
“type”: “float”,
“name”: “State of charge (%)”
“name”: “Soc %”,
“onlyChanges”: true,
“roundValues”: “2”,
“x”: 230,
“y”: 400,
“wires”: [
“a0decc5198a27487”,
“6c01ba4e599dbe27”,
“a3fa383c1ac87428”
“id”: “a0decc5198a27487”,
“type”: “debug”,
“name”: “debug 53”,
“active”: true,
“tosidebar”: true,
“console”: false,
“tostatus”: false,
“complete”: “false”,
“statusVal”: “”,
“x”: 380,
“y”: 400,
“wires”:
“id”: “6c01ba4e599dbe27”,
“type”: “switch”,
“name”: “SOC>X an”,
“property”: “payload”,
“propertyType”: “msg”,
“rules”: [
“t”: “gte”,
“v”: “98”,
“vt”: “str”
“checkall”: “true”,
“repair”: true,
“outputs”: 1,
“x”: 550,
“y”: 220,
“wires”: [
“3d6b19b1c8d830eb”
“id”: “01a9515ff488c867”,
“type”: “inject”,
“name”: “Test SOC >X an”,
“props”: [
“p”: “payload”
“p”: “topic”,
“vt”: “str”
“repeat”: “”,
“crontab”: “”,
“once”: false,
“onceDelay”: 0.1,
“topic”: “”,
“payload”: “90”,
“payloadType”: “num”,
“x”: 540,
“y”: 340,
“wires”: [
“3d6b19b1c8d830eb”
“id”: “6a92b1cb4f2b8cf2”,
“type”: “inject”,
“name”: “Test SOC <X aus”,
“props”: [
“p”: “payload”
“p”: “topic”,
“vt”: “str”
“repeat”: “”,
“crontab”: “”,
“once”: false,
“onceDelay”: 0.1,
“topic”: “”,
“payload”: “84”,
“x”: 540,
“y”: 460,
“wires”: [
“1a02fd82b833a65a”
“id”: “a3fa383c1ac87428”,
“type”: “switch”,
“name”: “SOC<X aus”,
“rules”: [
“t”: “lte”,
“v”: “97”,
“vt”: “str”
“checkall”: “true”,
“repair”: true,
“outputs”: 1,
“x”: 550,
“y”: 560,
“wires”: [
“1a02fd82b833a65a”
“id”: “04263f2d054cc2a1”,
“type”: “shelly-gen2-server”,
“port”: “10001”,
“hostname”: “unimatrix”
mußte halt an Deine Bedürfnisse anpassen,
lG
Michael
Hallo Michael,
danke für diene Antwort und den Flow…
habe ihn kopiert und dann bei mir importiert und dann kam diese Fehlermeldung
Was habe ich falsch gemacht ?
Grüße
Rolf
