Hello .
I can’t find the On MPII AC2 out and primary relays. Could somebody please point me in the right direction?
The mp2 relays are only accessible from within the mp2 configuration using either virtual switch or assistants.
Thanks to confirm my consern. Don’t like this method. Node-Red is an easier way.
The primary input relay that is switched by the GX can be interacted with in node red.
You use the GX to switch the switch position.
