Good day wanted to know if someone had a virtual pv inverter and battery flow they can share so I can import into node red. Im new to node red and have some switches i would like to test.
Some switches and what do they have to do with the virtual pv inverter?
I have battery and virtual pv flows but what would the ones you want to be actually doing? The ones i have all do different things on each system
Hi I would like to activate a switch let’s say pool pump if solar gets above a value and if battery is above a soc level and switch off if below the values. I would like to controll the virtual devices with a slider.
