Add a battery inverter via Node Red?
I have several Installations in my VRM portal with varying degrees of Victron components. One Installation only uses a Cerbo GX and two MPPT Solar Chargers. A battery is also connected via CAN/BMS.
As you can imagine, that data collected within Venus / VRM is a bit sparse.
Using Node Red, I added my Shelly Pro3EM as a grid meter (works fine) however I’m still missing the “output” of my battery inverter. The battery inverter is “metered” via a shelly plug. I can add the shelly plug via Node Red, however if I chose a virtual device of type “PV Inverter” the energy is metered as native solar production and not seeas n energy coming from the 48V rail (especially the battery at night)
Is there any way to include a battery inverter into Node Red as of yet?
Thanks,
Dark-Sider
Hi, same here.
1 Multiplus via VE.Bus, the other via MK3. I managed to add a virtual PV Inverter in Node Red to have the correct AC Load sum, but now there is an extra PV Inverter block in the GUI..
would be great to have a pure “battery inverter” as virtual device!
thx
Walter
