I am no longer using the Node-RED DESS node, but a replacement using the VRM API node and some code stolen from the Node-RED DESS node. (as posted here)
This code will not yet work with 15 minute prices but I can adapt it as soon as the VRM api node returns the 15 minute schedules
Dynamic ESS mode 4 is “Node-red” 1 is auto (VRM) and 0 is off
"id": "db2675c26af8189a",
"type": "inject",
"z": "2bf3db9bfca4f392",
"g": "c018435c26989974",
"name": "Enable Dynamic ESS (mode: Node-RED)",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "4",
"payloadType": "num",
"x": 250,
"y": 60,
"wires": [
"9f355ad0aef74e42"
"id": "b2649c3356beac4c",
"type": "inject",
"name": "Disable Dynamic ESS (mode: auto)",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "1",
"x": 230,
"y": 100,
"wires": [
"9f355ad0aef74e42"
"id": "21a412f9205b4ad6",
"type": "inject",
"name": "Disable Dynamic ESS (mode: off)",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "0",
"x": 220,
"y": 140,
"wires": [
"9f355ad0aef74e42"
"id": "9f355ad0aef74e42",
"type": "victron-output-custom",
"service": "com.victronenergy.settings",
"path": "/Settings/DynamicEss/Mode",
"serviceObj": {
"name": "com.victronenergy.settings"
"pathObj": {
"name": "/Settings/DynamicEss/Mode",
"type": "number"
"name": "Dynamic ESS mode",
"onlyChanges": false,
"x": 630,
"y": 60,
"wires": []
