I assume, that with node-red is possible to get battery “time to go”. Am I right?
If so, could you please help me with that. I do not have any node-red skils, so Im like a monkey, who try to play piano… pretty much hopeless.
I have following components in use:
Multiplus I, not II, 48V, 230V/5000VA
3x MPPT 150/35
Venus GX
Pylontech battery 15.5kWh
I do NOT have any smart shunt
Im 98% off grid, but I also have grid connection.
If there is any kind person, who have done this already, could you share it with me, please.
(Would be really nice to have a node-red slider also, so I could adjust DOD of the battery)
I have looked from internet/youtube, but I could´t find any flow, which would work with my system…or I just dont know how to make it work, Im hopeless..
Thanks !!
I’ve not checked myself but I imagine that’s where the time to go indicator used by VRM comes from. In other words I’d guess the battery node in node red
IN regards to the slider is the one in VRM app not sufficient for you? Or are you looking to have a cloudless setup?
If you give some more detail about what you’re looking to have made I’m happy to lend a hand
Hi Matt,
Thanks for your reply and support. I have tested that dbus bath, but it doesnt work. I guess, if I would have a smart shunt, it would work, but I dont have a shunt. Without a shunt, I get payload “null”.
If I select custom input node, there I can see Pylontech battery, but under Pylontech battery measurements, there is no “time to go” option.
So I was thinking, that only option might be to do with node-red some programming.. Battery total capacity - min SOC% - consumption + MPPT PV production - 10% of losses…and so on.. and try to get calculated “Battery time to go time”. That slider that I mentioned, it would be for adjusting min SOC, so “Battery time to go time” would change depending on what is the min SOC level.
Thanks again for your support.
I’m less familiar with pylontech however out of curiosity what have you selected as your battery monitor within venus os/gx device. I thought the battery dbus would be populated with whatever device you had selected as your battery monitor in settings->system setup → battery monitor.
Hi LX,
Thanks for your reply. If you read my first message, you will see, that I have no any skills with node-red, Im pretty much hopeless. Thats why Im asking, if some really frendly person could help me out. Im sure, if I will drag 1 or 10 function nodes to the “workspace”, they are not going to solve my issue, without “telling them” what they should do. And on that point, Im getting lost, as I told, Im hopeless with node-red
I did try checking github to see how it’s calculated on victron devices. ANyone know where that would be, i thought maybe systemcalcs but i could spot it.
Hi LX,
Thanks again for your reply. Just a would like to see simple value for “battery time to go”. I have a Pylontech battery bank of 15.5kWh, and I usually keep min SOC level on 20%. Of course would be super nice to have a simple sider on dashboard, so I could adjust of min SOC level, but that would be a nice extra feature. Im 98% of grid, but I have also grid connection, just in case for rainy days.
Other equipment I do have are: Multiplus 5000VA/230V/48V, 3xMPPT150/35, venus GX
So you have built the entire dashboard by copying code?
If you have reached that far, then you should be able to build or modify one of those.
what i am saying is what you are asking for is not that simple. Especially when is come to integrating i to what you have already.
Fairly certain you are a logical person and can work out the math.
Hi LX,
Thanks for your reply. This dashboard was difficult enough for me. A lot of studing and of course, copy and paste from yhe internet, and then try…try…and try again But thats the problem, I dont know, how to do the code and all the math…
Ok one to try… Lets tackle one of your requests at a time.
We tried writing one with nodes found commonly on systems so transfer is less of an issue
You will need to edit battery capacity and it counts time to go to your min soc set in ess.
You will need to edit the battery capacity in AH in the function node
