NOde-red, battery time to go
Hi LX,
Now, I managd to use your flow. :slight_smile:
But Im not sure, if it calculates time to go right… I have 324Ah battery bank, 15.5kh.
Right now SOC is 81% = more or les 12.71 kWh and consumption is about 300W. If you devide 12.71kWh /0.300kW you will get 37 hours. With your flow, it shows time to go
Am I right… or really wrong as usually… ? :slight_smile: :slight_smile: :slight_smile:
Is this on ac?
Funny is matches my shunt on my system. Will test again
Yes, I have only AC consumption.
…Installed capacity …
…Minimum SOC
Do you have anything charging right now?
…and oly AC load
So you have some solar. The flow only uses what is being drawn from the battery which is 200w
Yes… we still have some daylight left after rainy day. So, I will wait till night and check time to go again. Thank you very much for your help. I will report back tommorrow !!! Thanks again !! :slight_smile:
…and if this will work… then the next step… “time to full” … :joy: But thats the another story.. :wink:
Hi LX,
WoW, “time to go AND time to full” works just great!! Thanks again a lot !! :slight_smile:
Of course, I got another idea as well.. :wink: Is it possible to do some fine tuning…? Now it show, “time to go and time to full”, but is it possible to get also separate info, on what time battery bank would be empty OR fully charged? So, I would see that time to go and time to full as I see it now, but also on what time the battery bank would be full. For example, additional information: “Batteries full at 14.35” :slight_smile: That would do the life a little bit easier.. :slight_smile: Of course, Im super happy with with this information what I get now… but that "Batteries full at XX.XX would be a great bonus. :slight_smile: Thanks again !!
It is but the work now to do it and test it. These are services the company i work for charges for. So there is a fine line between me helping and then giving away services for free.
Hi LX,
Dont worry, I really understund your point, so no problem, if you are not able to help me with this bonus case… so no problem at all. :slight_smile: Im already super happy with this “time to go” case. Thank you so much !!! :slight_smile: I really appreciate your help !!
