I don’t have a toggle swicht on venus os 3.66 and also on the beta version. I can’t use 3.66 because it won’t communicate wit my solaredge inverter. they say there is a fix but that is a bug. Is it possible to activate it in another way or do i need to reinstall my cerbo gx?
Is dess set up in the vrm online portal though?
Yes it is, and it is working after a reset of some data. I’ve still got 1 big problem with the beta as well as the stable version, my solaredge wil lose connection every day. It is a solaredge se3000h with tcp sunspec protocol. Firmware on the inverter is the newest one. I’m busy with solaredge to get an older firmware, but is not an easy process.
It seems that i suffer from the same problem. I accidently sitched off the dynamic ESS in the Menu and now the toggle switch is gone. In VRM the DESS-settings are all put in, it has worked so far for quite some time. Any hints?
Found it myself. You have to switch it back on via the VRM Dashboard. Then the menu and toogle switch will reappear.
