No remote console via Victron Connect bluetooth local any more
Suddenly when i connect via Bluetooth to the Cerbo, i do not get the remote console option any more.
I do get it via VRM and LAN, what is the explanation for this?
Are you in the same LAN/WLAN with your phone/tablet?
I try to connect via Bluetooth, no, not in the same LAN/WLAN
I now have a lot more issues with the Cerbo, it also does not connect with VRM anymore.
I already did reset it to factory settings.
If you connect via Bluetooth you only have the “Remote-Console” button if you are connected to the same network as the GX device.
Oké, that is clear than.
