No charge of lithium, BMS says "Yes" -Solved
Hi
During winter I had my 2x 200Ah Victron NG at home and totally disconnected. Today when put them into my boat everything looks fine however there are some issues with charging. The smallBMS says yes to charging but my smartsolar mppt’s says that bms says No. If disconnnect VE.direct (non-inverting remote) it starts. I’ve got 3 smartsolar mppt’s but all says No for charging.
Everything is updated and worked perfect during autumn.
BMS:
Smartsolar:
To answer myself. It was a bad cable joint on the remote cable that caused the issue. Easy and cheat fix.:wink::hugs:
