I have two NG batteries. The kinda middle NG bms, not the Lynx and not the small one, plus the cerbo gx. The NG batteries have a temperature sensor built in and from what I understand the Lynx NG BMS can read the temperature and cerbo and read it. Is it possible that victron just needs to update the Middle BMS so it can also read the information from the batteries, or is it something that cannot happen. What I want to do is use the NG battery temp sensor to trigger the cerbo relay to turn on and off heat pads. At the moment I’m having to use external temp sensor through the cerbo, which is located in the battery compartment , wouldnt it be better to use the actual battery temp.
Related topics
| Topic | Replies | Views | Activity | |
| Victron Batterien NG 12,8V --> Integration an Cerbo-System ausschließlich mit Lynx-Smart-NG-BMS? | 5 | 158 | 16 December 2025 | |
| How to monitor all Victron NG battery temperatures simultaneously | 0 | 81 | 16 August 2026 | |
| Please Add Support for Relays Based on Battery Temperature in Cerbo GX | 6 | 295 | 24 May 2025 | |
| Bug_Report - Wrong battery temperature displayed on overview page | 3 | 82 | 9 May 2026 | |
| Lynx Smart NG BMS monitoring | 1 | 65 | 31 May 2026 |
