New UI as default
I use Venus on Raspberry Pi and have set it all up fine. I want to use the New UI all the time and have tried and failed to change settings to achieve this. Specifically, I want the “Remote Console | Overview” page to be the default page to load when I log in to the VRM. Alternatively I’d be happy to just have the link to this page so I don’t have to keep pressing Remote Console then New UI each time I was to use it.
How can I achieve this ?
@Mark2 You can run venus.local from your browser if the device you access vrm with is on the same LAN as the pi. That should bring up the rcsonsole with the GUI you configured it with. I don’t believe you can set the rconsole as a “starting page” in VRM or start it up automatically when opening VRM.
