New off-grid system setup with ecoworthy 100Ah 48V, CerboGX and 6000VA 48V smartsolar
Hi Can anyone send me a simple wiring diagram for the communication connections between the Inverter, Cerbo and Ecoworthy battery? Although I have installed 4 of my own system with increasing power and complexity nothing prepared me for the complexity that comes with devices designed to do more than simply provide solar power and the reams of pages of complex wiring diagrams and instructions for stuff I don’t need and will never use (such as tank monitors). Just need to wire up and switch on. A friend of mine is laughing at me because he bought an Easun power inverter and just wired up to the same batteries as me and is enjoying uninterrupted power now while I am having to apply to read for a PhD in simplifying Victron product litterature.
The available Victron manuals are hugely complex as they are addressing a plethora of applications above and beyond just supplying power.
But you wont be done with “wire up and switch on”. The system needs configuring
Might be laughing now, but time will tell.
Ia gojng to assume the physical cables like battery fuses etc aren’t an issue since you have done inverter systems before.
It is a patch cable for the ve bus and the battery (doesn’t actually need comms) isn’t on the compatible list. But a can cable mightwork.
As an fyi if you skip ground on can a or b they are the same.
You will definitely need to program the inverter and mppt.
thankyou!
