Cerbo Gx showing up in list off recently connected to the network.
In the history plenty times connected & clearly gone.
At the same time I see Venus wich is permanent.
(Sreenshots are from Eset Network Scanner)
What is that Cerbo Gx that comes en goes away?
Is this not the reason that I loose connection with Node Red while working on the local network? Dashboard saying ‘lost connection’ & if uploading flow saying 'Node Red not … '?
