Hello everyone,
I’m currently working on an industrial integration project where I need to connect an energy meter directly to a MES system via KEPServerEX using Modbus TCP over Ethernet.
Initially, I was considering the Victron VM-3P75CT model, but unfortunately I couldn’t find any official Modbus TCP register map or documentation listing the detailed register addresses for this device.
Could someone from Victron or the community help with the following points:
Is there an official Modbus TCP register map available for the VM-3P75CT?
If not, is there any recommended method to extract or access the full list of registers (maybe via VictronConnect, Cerbo GX, or other tools)?
Has anyone here already integrated this model with KEPServerEX, or with any industrial SCADA/MES system?
Alternatively, does Victron have any other energy meter models officially designed and documented for Modbus TCP industrial integrations (where registers and scaling factors are clearly published)?
My goal is to get a meter with known and documented Modbus TCP registers, so that I can configure it easily in KEPServerEX without trial and error.
Any help, documentation, or suggestions for alternative Victron models (or even third-party meters) that meet this need would be greatly appreciated.
Thanks a lot for your support!
Best regards
