This is my Victron powered solar power box running 2 Victron 250 / 100 mppt’s along with 2 blue smart AC to DC chargers in parlell. Then I have a Dc to Dc charger - OS 1400 then I have the smart shunt and smart sence. Im running 2 12 volt = 24 volt x3 parraled through the bus bars to a box of batteries in series hooked paralell through through the bus bar. Then im running 8 400 watt solar pannels 4 in series on
each mppt.
Is the whole set up (besides the solar panels) in the box?
each mppt.
Yes it is. Im runing 8 fans through vents the 4 inside the box push and the 4 fans on top of the box pull air out. Its working however ive got a 10 amp step down converter 6.5 volts to run more fans 8 are 120 mm but im thinking of adding some more fans closer to the 2 mppts. That’s the most heat the system creates is during the day and honestlybits not too bad. I just dont mind using 30 watfs to keep my system cool and ventalated. The.n the standby power at night dosnt even register as a watt. Its very efficient on stand by.
Im In the process of rebuilding the box at the moment to be sure i torqueall my bus bars to spec and rout the cables cleaner than the first assembly. I will add mor pictures once jve got it back together. I oversized the lugz and cables along with running 24.volt to try and keep things cooler inside the box.
What i need is somkind of sensor or app that monitors temptetures through out the day so I can see what’s going on better. For now I monif ll tor it with a heat camera and lazer thermometer
. If yoy know of any heat monitoring apps that would be helpful please let me know.
Ruuvi is the first one that cones to mind and they integrate with a GX if you ever decide to add one.
Wow that ruvvi is almost exactly what I nded accept im justt clmpleey maxed out on space to run the cerbo GX. It would be nice. Im trying to think of any way it could be used with 5he connect app. If not ill just check out the Ruuvi software. It looks like i can implement it one way or another. Thanks for suggesting that. Much appreciated.
