Can I somehow use the 230 from the Multiplus when on landpower without charging the batteries?
Straight out of the box, no.
If you have a GX device, yes.
If you have a MK3-USB interface, you can disable charge via a laptop or android phone.
You can also do it with a source inverter, which allow you to choose if the landpower go throught the multiplus or directly to your 230V system…
But i don’t understand why you don’t want to charge battery
