Thank you to all those who commented. At the end, it turned out that the root cause of my problem was a mismatch between the firmware on the MultiPlus (after upgrade) and what CErbo GX thought the firmware version is. We fixed it by re-upgrading the Multi to the latest firmware (552), deleting the (old) Multi from the VRM and rebooting the Cerbo GX twice, followed by rediscovery of the VE.bus devices - which after quite a long time (circa 20 minutes) resulted in updating the Multi parameters on the Cerbo and both of them working fine again.
vuca-mavens
(Pawel Stefanski)
6
Related topics
| Topic | Replies | Views | Activity | |
| Phoenix Multiplus 3000 24 Firmware upgrade | 2 | 106 | 2 November 2025 | |
| Multiplus Compact 12/2000/80 not connecting to Cerbo GX after firmware 2608 update | 27 | 169 | 9 June 2026 | |
| Keine Verbindung von Multiplus Compact 12/1600/70-16 mit Cerbo GX nach Firmware Update | 3 | 179 | 11 June 2025 | |
| [Solved] Multiplus stops as soon as Cerbo GX is connected | 3 | 358 | 30 July 2025 | |
| Multiplus-II und Cerbo-GX wollen nicht zusammen | 13 | 1049 | 9 February 2025 |
